Beam Design - Beam
Size: 2.5 x 15
Design Span (L): 14.67 ft.
Clear Span: 14.33 ft.
Total Span: 15.00 ft.
Bearing (lb): 4 in.
Live Load: 450 plf
Dead Load: 337 plf
Selfweight: 129.0 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 131.9 lbs
Load Duration: 1.33
Beam Design 2201
7/9/2022 1
b = 2.500 in.
d = 15.000 in.
A = 2.500 x 15.000 = 37.50 in.2
Sx = (2.500)(15.000)2/6 = 93.75 in.3
Sy = (2.500)2(15.000)/6 = 15.63 in.3
Ix = (2.500)(15.000)3/12 = 703.13 in.4
Iy = (2.500)3(15.000)/12 = 19.53 in.4
Beam Design 2201
7/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (176.00 + 4)] x (12 in./ft.)3 = 3.91 ft3
Volumespan = N[A x L] = 1 x [37.50 x 176.00] x (12 in./ft.)3 = 3.82 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.91 = 131.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.82 = 129.0 lbs
450 plf
337 plf
  ws = 8.79 plf
14.67 ft.
14.33 ft.
15.00 ft.
5968.57 lbs
5968.57 lbs
Beam Design 2201
7/9/2022 3
Fbx' = (2400)(1.33)(1)(1)(1.0) = 3192.0 psi
fb = = 2739.1 psi
 fb = 2739.1 psi < Fbx' = 3192.0 psi  (CSI = 0.86)   ➜  OK
Beam Design 2201
7/9/2022 4
Fvx' = (265)(1.33)(1)(1) = 352.45 psi
fv* = = 193.65 psi
 fv* = 193.65 psi < Fvx' = 352.45 psi  (CSI = 0.55)   ➜  OK
fv = = 233.44 psi
 fv = 233.44 psi < Fvx' = 352.45 psi  (CSI = 0.66)   ➜  OK
Beam Design 2201
7/9/2022 5
ΔLL = = 0.37 in.
(L/d)LL = 176.00 / 0.37 = 475
 ΔLL = 0.37 in = L/475 < L/360   ➜  OK
ΔTL = = 0.65 in.
(L/d)TL = 176.00 / 0.65 = 269
 ΔTL = 0.65 in = L/269 < L/240   ➜  OK
Ab = b x lb = 2.5 x 4 = 10.00 in2
fc⊥ = = 596.9 psi
 fc⊥ = 596.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.92)   ➜  OK
Beam Design 2201
7/9/2022 6
