Beam Design - Beam
Size: 3.125 x 16.5
Design Span (L): 14.67 ft.
Clear Span: 14.33 ft.
Total Span: 15.00 ft.
Bearing (lb): 4 in.
Live Load: 450 plf
Dead Load: 337 plf
Selfweight: 177.3 lbs
Dist. Selfweight: 12.09 plf
Total Weight: 181.3 lbs
Load Duration: 1.33
Beam Design 2201
7/9/2022 1
b = 3.125 in.
d = 16.500 in.
A = 3.125 x 16.500 = 51.56 in.2
Sx = (3.125)(16.500)2/6 = 141.80 in.3
Sy = (3.125)2(16.500)/6 = 26.86 in.3
Ix = (3.125)(16.500)3/12 = 1169.82 in.4
Iy = (3.125)3(16.500)/12 = 41.96 in.4
Beam Design 2201
7/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [51.56 x (176.00 + 4)] x (12 in./ft.)3 = 5.37 ft3
Volumespan = N[A x L] = 1 x [51.56 x 176.00] x (12 in./ft.)3 = 5.25 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.37 = 181.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.25 = 177.3 lbs
Distributed Self Weight (ws) = = 12.09 plf
450 plf
337 plf
  ws = 12.09 plf
14.67 ft.
14.33 ft.
15.00 ft.
5993.30 lbs
5993.30 lbs
Beam Design 2201
7/9/2022 3
Fbx' = (2400)(1.33)(1)(1)(1.0) = 3192.0 psi
fb = = 1818.5 psi
 fb = 1818.5 psi < Fbx' = 3192.0 psi  (CSI = 0.57)   ➜  OK
Beam Design 2201
7/9/2022 4
Fvx' = (265)(1.33)(1)(1) = 352.45 psi
fv* = = 138.51 psi
 fv* = 138.51 psi < Fvx' = 352.45 psi  (CSI = 0.39)   ➜  OK
fv = = 170.48 psi
 fv = 170.48 psi < Fvx' = 352.45 psi  (CSI = 0.48)   ➜  OK
Beam Design 2201
7/9/2022 5
ΔLL = = 0.22 in.
(L/d)LL = 176.00 / 0.22 = 791
 ΔLL = 0.22 in = L/791 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 176.00 / 0.40 = 445
 ΔTL = 0.40 in = L/445 < L/240   ➜  OK
Ab = b x lb = 3.125 x 4 = 12.50 in2
fc⊥ = = 479.5 psi
 fc⊥ = 479.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.74)   ➜  OK
Beam Design 2201
7/9/2022 6
