Beam Design - Ceiling Beam
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Selfweight: 140.9 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 143.4 lbs
Beam Design Scott Morris 1147 3rd Street 1147 3rd Street
7/9/2022 1
7/9/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (171.00 + 3)] x (12 in./ft.)3 = 4.19 ft3
Volumespan = N[A x L] = 3 x [13.88 x 171.00] x (12 in./ft.)3 = 4.12 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.19 = 143.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.12 = 140.9 lbs
ws = 9.89 plf
14.25 ft.
14.50 ft.
1340.43 lbs
1340.43 lbs
7/9/2022 3
fb = = 877.6 psi
 fb = 877.6 psi < Fbx' = 990.0 psi  (CSI = 0.89)   ➜  OK
7/9/2022 4
fv* = = 42.34 psi
 fv* = 42.34 psi < Fvx' = 180.00 psi  (CSI = 0.24)   ➜  OK
fv = = 47.47 psi
 fv = 47.47 psi < Fvx' = 180.00 psi  (CSI = 0.26)   ➜  OK
7/9/2022 5
ΔLL = = 0.20 in.
(L/d)LL = 171.00 / 0.20 = 875
 ΔLL = 0.20 in = L/875 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 171.00 / 0.36 = 473
 ΔTL = 0.36 in = L/473 < L/240   ➜  OK
fc⊥ = = 99.3 psi
 fc⊥ = 99.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
7/9/2022 6
