Size: 4 x 8
Design Span (L): 6.08 ft.
Clear Span: 5.83 ft.
Total Span: 6.33 ft.
Selfweight: 36.7 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 38.2 lbs
Load Duration: 1.25
Beam Design 2022A502
7/9/2022 1
7/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (73.00 + 3)] x (12 in./ft.)3 = 1.12 ft3
Volumespan = N[A x L] = 1 x [25.38 x 73.00] x (12 in./ft.)3 = 1.07 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.12 = 38.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.07 = 36.7 lbs
ws = 6.03 plf
6.08 ft.
5.83 ft.
6.33 ft.
573.22 lbs
573.22 lbs
7/9/2022 3
Fbx' = (900)(1.25)(1)(1)(1)(1.3)(1)(1) = 1462.5 psi
fb = = 327.7 psi
 fb = 327.7 psi < Fbx' = 1462.5 psi  (CSI = 0.22)   ➜  OK
7/9/2022 4
fv* = = 26.08 psi
 fv* = 26.08 psi < Fvx' = 225.00 psi  (CSI = 0.12)   ➜  OK
fv = = 32.55 psi
 fv = 32.55 psi < Fvx' = 225.00 psi  (CSI = 0.14)   ➜  OK
7/9/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 73.00 / 0.02 = 4214
 ΔLL = 0.02 in = L/4214 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 73.00 / 0.03 = 2328
 ΔTL = 0.03 in = L/2328 < L/240   ➜  OK
fc⊥ = = 54.6 psi
 fc⊥ = 54.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
7/9/2022 6
