Beam Design - BEAM-3-4-B
Size: 3.5 x 7.5
Design Span (L): 15.67 ft.
Clear Span: 15.42 ft.
Total Span: 15.92 ft.
Live Load: 320 plf
Dead Load: 112 plf
Selfweight: 192.9 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 196.0 lbs
Beam Design 21-034
7/9/2022 1
d = 7.500 in.
A = 3.500 x 7.500 = 26.25 in.2
Sx = (3.500)(7.500)2/6 = 32.81 in.3
Sy = (3.500)2(7.500)/6 = 15.31 in.3
Ix = (3.500)(7.500)3/12 = 123.05 in.4
Iy = (3.500)3(7.500)/12 = 26.80 in.4
Beam Design 21-034
7/9/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [26.25 x (188.04 + 3)] x (12 in./ft.)3 = 5.80 ft3
Volumespan = N[A x L] = 2 x [26.25 x 188.04] x (12 in./ft.)3 = 5.71 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.80 = 196.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.71 = 192.9 lbs
320 plf
112 plf
  ws = 12.31 plf
15.67 ft.
15.42 ft.
15.92 ft.
3536.70 lbs
3536.70 lbs
Beam Design 21-034
7/9/2022 3
fb = = 2493.7 psi
 fb = 2493.7 psi < Fbx' = 2760.0 psi  (CSI = 0.90)   ➜  OK
Beam Design 21-034
7/9/2022 4
fv* = = 91.53 psi
 fv* = 91.53 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
fv = = 99.46 psi
 fv = 99.46 psi < Fvx' = 304.75 psi  (CSI = 0.33)   ➜  OK
Beam Design 21-034
7/9/2022 5
ΔLL = = 0.98 in.
(L/d)LL = 188.04 / 0.98 = 192
 ΔLL = 0.98 in = L/192 < L/180   ➜  OK
ΔTL = = 1.36 in.
(L/d)TL = 188.04 / 1.36 = 138
 ΔTL = 1.36 in = L/138 < L/120   ➜  OK
fc⊥ = = 168.4 psi
 fc⊥ = 168.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.26)   ➜  OK
Beam Design 21-034
7/9/2022 6
