Design Span (L): 13.50 ft.
Clear Span: 13.00 ft.
Total Span: 14.00 ft.
Live Load: 180 plf
Dead Load: 204 plf
Selfweight: 177.2 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 183.7 lbs
Load Duration: 1.33
Beam Design 2022A494
7/8/2022 1
7/8/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (162.00 + 6)] x (12 in./ft.)3 = 4.92 ft3
Volumespan = N[A x L] = 3 x [16.88 x 162.00] x (12 in./ft.)3 = 4.75 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.92 = 183.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.75 = 177.2 lbs
180 plf
204 plf
ws = 13.12 plf
13.50 ft.
13.00 ft.
2779.87 lbs
2779.87 lbs
7/8/2022 3
Fbx' = (750)(1.33)(1)(1)(1)(1)(1)(1.15) = 1147.1 psi
fb = = 1143.7 psi
 fb = 1143.7 psi < Fbx' = 1147.1 psi  (CSI = 1.00)   ➜  OK
7/8/2022 4
Fvx' = (175)(1.33)(1)(1)(1) = 232.75 psi
fv* = = 68.39 psi
 fv* = 68.39 psi < Fvx' = 232.75 psi  (CSI = 0.29)   ➜  OK
fv = = 79.42 psi
 fv = 79.42 psi < Fvx' = 232.75 psi  (CSI = 0.34)   ➜  OK
7/8/2022 5
ΔLL = = 0.18 in.
(L/d)LL = 162.00 / 0.18 = 900
 ΔLL = 0.18 in = L/900 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 162.00 / 0.40 = 408
 ΔTL = 0.40 in = L/408 < L/240   ➜  OK
fc⊥ = = 103.0 psi
 fc⊥ = 103.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.18)   ➜  OK
7/8/2022 6
