Beam Design - BEAM B1 CALCULATION
Grade: DF No.1 & Btr
Size: 4 x 16
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 220 plf
Dead Load: 85.25 plf
Selfweight: 202.6 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 205.8 lbs
Incised Lumber: Yes
Notes: Re-Calculation for the beam over the kitchen replacing for the removed wall.
Beam Design 12587 Morgan Ln, Garden Grove, CA 92840 P37
7/8/2022 1
d = 15.000 in.
7/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (195.00 + 3)] x (12 in./ft.)3 = 6.02 ft3
Volumespan = N[A x L] = 1 x [52.50 x 195.00] x (12 in./ft.)3 = 5.92 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 6.02 = 205.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.92 = 202.6 lbs
220 plf
85.25 plf
ws = 12.47 plf
16.25 ft.
16.50 ft.
2621.19 lbs
2621.19 lbs
7/8/2022 3
Fbx' = (1200)(1.00)(1)(1)(1)(1)(0.8)(1.15) = 1104.0 psi
fb = = 958.8 psi
 fb = 958.8 psi < Fbx' = 1104.0 psi  (CSI = 0.87)   ➜  OK
7/8/2022 4
Fvx' = (180)(1.00)(1)(1)(0.8) = 144.00 psi
fv* = = 62.41 psi
 fv* = 62.41 psi < Fvx' = 144.00 psi  (CSI = 0.43)   ➜  OK
fv = = 73.76 psi
 fv = 73.76 psi < Fvx' = 144.00 psi  (CSI = 0.51)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1800000(1)(1)(0.95) = 1710000 psi
7/8/2022 5
ΔLL = = 0.21 in.
(L/d)LL = 195.00 / 0.21 = 951
 ΔLL = 0.21 in = L/951 < L/360   ➜  OK
ΔTL = = 0.30 in.
(L/d)TL = 195.00 / 0.30 = 658
 ΔTL = 0.30 in = L/658 < L/240   ➜  OK
fc⊥ = = 249.6 psi
 fc⊥ = 249.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.40)   ➜  OK
7/8/2022 6
