Beam Design - BEAM B1 CALCULATION
Grade: DF No.1 & Btr
Size: 4 x 16
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 220 plf
Dead Load: 220 plf
Selfweight: 202.6 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 205.8 lbs
Notes: Re-Calculation for the beam over the kitchen replacing for the removed wall.
Beam Design 12587 Morgan Ln, Garden Grove, CA 92840 P37
7/8/2022 1
d = 15.000 in.
7/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (195.00 + 3)] x (12 in./ft.)3 = 6.02 ft3
Volumespan = N[A x L] = 1 x [52.50 x 195.00] x (12 in./ft.)3 = 5.92 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 6.02 = 205.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.92 = 202.6 lbs
220 plf
220 plf
ws = 12.47 plf
16.25 ft.
16.50 ft.
3732.88 lbs
3732.88 lbs
7/8/2022 3
Fbx' = (1200)(1.00)(1)(1)(1)(1)(1)(1) = 1200.0 psi
fb = = 1365.5 psi
 fb = 1365.5 psi > Fbx' = 1200.0 psi  (CSI = 1.14)   ➜  NG
7/8/2022 4
fv* = = 88.88 psi
 fv* = 88.88 psi < Fvx' = 180.00 psi  (CSI = 0.49)   ➜  OK
fv = = 105.04 psi
 fv = 105.04 psi < Fvx' = 180.00 psi  (CSI = 0.58)   ➜  OK
7/8/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 195.00 / 0.19 = 1001
 ΔLL = 0.19 in = L/1001 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 195.00 / 0.40 = 487
 ΔTL = 0.40 in = L/487 < L/240   ➜  OK
fc⊥ = = 355.5 psi
 fc⊥ = 355.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.57)   ➜  OK
7/8/2022 6
