Grade: DF No.1
Size: 4 x 6
Design Span (L): 15.25 ft.
Clear Span: 15.00 ft.
Total Span: 15.50 ft.
Selfweight: 69.7 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 70.9 lbs
Orientation: Horizontal
Beam Design 2022A49
1/26/2022 1
Beam Design 2022A49
1/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (183.00 + 3)] x (12 in./ft.)3 = 2.07 ft3
Volumespan = N[A x L] = 1 x [19.25 x 183.00] x (12 in./ft.)3 = 2.04 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.07 = 70.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.04 = 69.7 lbs
ws = 4.57 plf
15.25 ft.
15.00 ft.
15.50 ft.
1391.69 lbs
1391.69 lbs
Beam Design 2022A49
1/26/2022 3
Fby' = (1000)(1.00)(1)(0.8)(1)(1.3)(1.05)(1)(1) = 1092.0 psi
fb = = 5578.6 psi
 fb = 5578.6 psi > Fby' = 1092.0 psi  (CSI = 5.11)   ➜  NG
Beam Design 2022A49
1/26/2022 4
Fvy' = (180)(1.00)(1)(0.8)(1) = 144.00 psi
fv* = = 102.61 psi
 fv* = 102.61 psi < Fvy' = 144.00 psi  (CSI = 0.71)   ➜  OK
fv = = 106.69 psi
 fv = 106.69 psi < Fvy' = 144.00 psi  (CSI = 0.74)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1700000(1)(0.9)(1) = 1530000 psi
Beam Design 2022A49
1/26/2022 5
ΔLL = = 4.05 in.
(L/d)LL = 183.00 / 4.05 = 45
 ΔLL = 4.05 in = L/45 > L/360   ➜  NG
ΔTL = = 7.27 in.
(L/d)TL = 183.00 / 7.27 = 25
 ΔTL = 7.27 in = L/25 > L/240   ➜  NG
Fc⊥y' = (625)(1)(0.8)(1) = 500.00 psi
Ab = d x lb = 5.5 x 3 = 16.50 in2
fc⊥ = = 84.3 psi
 fc⊥ = 84.3 psi < Fc⊥y' = 500.00 psi  (CSI = 0.17)   ➜  OK
Beam Design 2022A49
1/26/2022 6
