Beam Design - THOMPSON ADDITION
Size: 4 x 10
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 360 plf
Dead Load: 20 plf
Selfweight: 69.8 lbs
Dist. Selfweight: 7.97 plf
Total Weight: 71.8 lbs
Incised Lumber: Yes
CL Beam Stability Factor 0.984 - - - - -
Beam Design Taylor Thompson 2022A485
7/7/2022 1
7/7/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (105.00 + 3)] x (12 in./ft.)3 = 2.02 ft3
Volumespan = N[A x L] = 1 x [32.38 x 105.00] x (12 in./ft.)3 = 1.97 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.02 = 71.8 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.97 = 69.8 lbs
Distributed Self Weight (ws) = = 7.97 plf
360 plf
20 plf
ws = 7.97 plf
8.75 ft.
8.50 ft.
9.00 ft.
1745.88 lbs
1745.88 lbs
7/7/2022 3
lu = Unbraced Length = 8.750 ft.
lu/d = = 11.35
le = 1.63lu + 3d = 1.63(105.0) + 3(9.25) = 198.90 in. = 16.57 ft.  (NDS Table 3.3.3)
Rb = = 12.26
 Rb = 12.26 < 50   ➜  OK
7/7/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(0.9)(1)(0.95) = 495900 psi
FbE = = 3962.19 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.2)(0.8)(1) = 993.60 psi
CL =   = 0.984
Fbx' = (900)(1.15)(1)(1)(0.984)(1.2)(0.8)(1) = 977.6 psi
fb = = 892.7 psi
 fb = 892.7 psi < Fbx' = 977.6 psi  (CSI = 0.91)   ➜  OK
fv* = = 64.79 psi
 fv* = 64.79 psi < Fvx' = 160.63 psi  (CSI = 0.40)   ➜  OK
fv = = 78.64 psi
 fv = 78.64 psi < Fvx' = 160.63 psi  (CSI = 0.49)   ➜  OK
7/7/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 105.00 / 0.15 = 698
 ΔLL = 0.15 in = L/698 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 105.00 / 0.16 = 648
 ΔTL = 0.16 in = L/648 < L/240   ➜  OK
fc⊥ = = 166.3 psi
 fc⊥ = 166.3 psi < Fc⊥x' = 418.75 psi  (CSI = 0.40)   ➜  OK
7/7/2022 6
