Beam Design - 1 2X8 BEAM
Design Span (L): 7.33 ft.
Clear Span: 7.17 ft.
Total Span: 7.50 ft.
Bearing (lb): 2 in.
Live Load: 150 plf
Dead Load: 8 plf
Selfweight: 18.9 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 19.4 lbs
Beam Design Barb Potter 2201
7/7/2022 1
7/7/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (88.00 + 2)] x (12 in./ft.)3 = 0.57 ft3
Volumespan = N[A x L] = 1 x [10.88 x 88.00] x (12 in./ft.)3 = 0.55 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.57 = 19.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.55 = 18.9 lbs
150 plf
8 plf
ws = 2.58 plf
7.33 ft.
7.17 ft.
7.50 ft.
602.16 lbs
602.16 lbs
7/7/2022 3
fb = = 985.7 psi
 fb = 985.7 psi < Fbx' = 1242.0 psi  (CSI = 0.79)   ➜  OK
7/7/2022 4
fv* = = 67.83 psi
 fv* = 67.83 psi < Fvx' = 207.00 psi  (CSI = 0.33)   ➜  OK
fv = = 81.21 psi
 fv = 81.21 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
7/7/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 88.00 / 0.13 = 687
 ΔLL = 0.13 in = L/687 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 88.00 / 0.14 = 642
 ΔTL = 0.14 in = L/642 < L/240   ➜  OK
fc⊥ = = 200.7 psi
 fc⊥ = 200.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.32)   ➜  OK
7/7/2022 6
