Beam Design - 2X6 BEAM
Design Span (L): 7.33 ft.
Clear Span: 7.17 ft.
Total Span: 7.50 ft.
Bearing (lb): 2 in.
Live Load: 150 plf
Dead Load: 8 plf
Selfweight: 28.7 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 29.4 lbs
Beam Design Barb Potter 2201
7/7/2022 1
7/7/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (88.00 + 2)] x (12 in./ft.)3 = 0.86 ft3
Volumespan = N[A x L] = 2 x [8.25 x 88.00] x (12 in./ft.)3 = 0.84 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.86 = 29.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.84 = 28.7 lbs
150 plf
8 plf
ws = 3.92 plf
7.33 ft.
7.17 ft.
7.50 ft.
607.17 lbs
607.17 lbs
7/7/2022 3
fb = = 863.5 psi
 fb = 863.5 psi < Fbx' = 1345.5 psi  (CSI = 0.64)   ➜  OK
7/7/2022 4
fv* = = 47.22 psi
 fv* = 47.22 psi < Fvx' = 207.00 psi  (CSI = 0.23)   ➜  OK
fv = = 53.97 psi
 fv = 53.97 psi < Fvx' = 207.00 psi  (CSI = 0.26)   ➜  OK
7/7/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 88.00 / 0.15 = 600
 ΔLL = 0.15 in = L/600 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 88.00 / 0.16 = 556
 ΔTL = 0.16 in = L/556 < L/240   ➜  OK
fc⊥ = = 101.2 psi
 fc⊥ = 101.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
7/7/2022 6
