Beam Design - BEA,
Design Span (L): 7.33 ft.
Clear Span: 7.17 ft.
Total Span: 7.50 ft.
Bearing (lb): 2 in.
Live Load: 150 plf
Dead Load: 8 plf
Selfweight: 37.9 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 38.7 lbs
Beam Design Barb Potter 2201
7/7/2022 1
7/7/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (88.00 + 2)] x (12 in./ft.)3 = 1.13 ft3
Volumespan = N[A x L] = 2 x [10.88 x 88.00] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.13 = 38.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.11 = 37.9 lbs
150 plf
8 plf
ws = 5.17 plf
7.33 ft.
7.17 ft.
7.50 ft.
611.85 lbs
611.85 lbs
7/7/2022 3
fb = = 500.8 psi
 fb = 500.8 psi < Fbx' = 1242.0 psi  (CSI = 0.40)   ➜  OK
7/7/2022 4
fv* = = 34.46 psi
 fv* = 34.46 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
fv = = 41.26 psi
 fv = 41.26 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
7/7/2022 5
ΔLL = = 0.06 in.
(L/d)LL = 88.00 / 0.06 = 1374
 ΔLL = 0.06 in = L/1374 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 88.00 / 0.07 = 1264
 ΔTL = 0.07 in = L/1264 < L/240   ➜  OK
fc⊥ = = 102.0 psi
 fc⊥ = 102.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
7/7/2022 6
