Grade: DF No.1 & Btr
Design Span (L): 7.75 ft.
Clear Span: 7.25 ft.
Total Span: 8.25 ft.
Selfweight: 31.5 lbs
Dist. Selfweight: 4.06 plf
Total Weight: 33.5 lbs
Beam Design 2022A469
7/5/2022 1
7/5/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (93.00 + 6)] x (12 in./ft.)3 = 0.95 ft3
Volumespan = N[A x L] = 2 x [8.25 x 93.00] x (12 in./ft.)3 = 0.89 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.95 = 33.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.89 = 31.5 lbs
Distributed Self Weight (ws) = = 4.06 plf
ws = 4.06 plf
7.75 ft.
7.25 ft.
8.25 ft.
738.64 lbs
738.64 lbs
7/5/2022 3
Fbx' = (1200)(1.15)(0.85)(1)(1)(1.3)(1)(1) = 1524.9 psi
fb = = 1066.6 psi
 fb = 1066.6 psi < Fbx' = 1524.9 psi  (CSI = 0.70)   ➜  OK
7/5/2022 4
fv* = = 55.62 psi
 fv* = 55.62 psi < Fvx' = 200.79 psi  (CSI = 0.28)   ➜  OK
fv = = 63.08 psi
 fv = 63.08 psi < Fvx' = 200.79 psi  (CSI = 0.31)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1800000(0.9)(1)(1) = 1620000 psi
7/5/2022 5
ΔLL = = 0.12 in.
(L/d)LL = 93.00 / 0.12 = 772
 ΔLL = 0.12 in = L/772 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 93.00 / 0.22 = 431
 ΔTL = 0.22 in = L/431 < L/240   ➜  OK
fc⊥ = = 41.0 psi
 fc⊥ = 41.0 psi < Fc⊥x' = 418.75 psi  (CSI = 0.10)   ➜  OK
7/5/2022 6
