Size: 4 x 12
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 133 plf
Dead Load: 10 plf
Selfweight: 147.3 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 149.6 lbs
Incised Lumber: Yes
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A467
7/5/2022 1
7/5/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (189.00 + 3)] x (12 in./ft.)3 = 4.38 ft3
Volumespan = N[A x L] = 1 x [39.38 x 189.00] x (12 in./ft.)3 = 4.31 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.38 = 149.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.31 = 147.3 lbs
133 plf
10 plf
ws = 9.35 plf
15.75 ft.
15.50 ft.
1218.82 lbs
1218.82 lbs
7/5/2022 3
Fbx' = (900)(1.00)(1)(1)(1)(1.1)(0.8)(1.15) = 910.8 psi
fb = = 767.9 psi
 fb = 767.9 psi < Fbx' = 910.8 psi  (CSI = 0.84)   ➜  OK
7/5/2022 4
Fvx' = (180)(1.00)(1)(1)(0.8) = 144.00 psi
fv* = = 40.26 psi
 fv* = 40.26 psi < Fvx' = 144.00 psi  (CSI = 0.28)   ➜  OK
fv = = 45.71 psi
 fv = 45.71 psi < Fvx' = 144.00 psi  (CSI = 0.32)   ➜  OK
7/5/2022 5
ΔLL = = 0.29 in.
(L/d)LL = 189.00 / 0.29 = 648
 ΔLL = 0.29 in = L/648 < L/360   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 189.00 / 0.33 = 566
 ΔTL = 0.33 in = L/566 < L/240   ➜  OK
fc⊥ = = 116.1 psi
 fc⊥ = 116.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
7/5/2022 6
