Design Span (L): 11.58 ft.
Clear Span: 11.17 ft.
Bearing (lb): 5 in.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 49.5 lbs
Dist. Selfweight: 4.28 plf
Total Weight: 51.3 lbs
Beam Design 2022A464
7/4/2022 1
7/4/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (139.00 + 5)] x (12 in./ft.)3 = 1.37 ft3
Volumespan = N[A x L] = 2 x [8.25 x 139.00] x (12 in./ft.)3 = 1.33 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.37 = 51.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.33 = 49.5 lbs
Distributed Self Weight (ws) = = 4.28 plf
40 plf
10 plf
ws = 4.28 plf
11.58 ft.
11.17 ft.
325.66 lbs
325.66 lbs
7/4/2022 3
fb = = 722.2 psi
 fb = 722.2 psi < Fbx' = 1000.0 psi  (CSI = 0.72)   ➜  OK
7/4/2022 4
fv* = = 26.32 psi
 fv* = 26.32 psi < Fvx' = 175.00 psi  (CSI = 0.15)   ➜  OK
fv = = 28.58 psi
 fv = 28.58 psi < Fvx' = 175.00 psi  (CSI = 0.16)   ➜  OK
7/4/2022 5
ΔLL = = 0.28 in.
(L/d)LL = 139.00 / 0.28 = 500
 ΔLL = 0.28 in = L/500 < L/360   ➜  OK
ΔTL = = 0.38 in.
(L/d)TL = 139.00 / 0.38 = 368
 ΔTL = 0.38 in = L/368 < L/240   ➜  OK
Ab = b x lb = 1.5 x 5 = 7.50 in2
fc⊥ = = 21.7 psi
 fc⊥ = 21.7 psi < Fc⊥x' = 565.00 psi  (CSI = 0.04)   ➜  OK
7/4/2022 6
