Size: 3.5 x 13.5
Design Span (L): 18.50 ft.
Clear Span: 18.25 ft.
Total Span: 18.75 ft.
Live Load: 207.5 plf
Dead Load: 124.5 plf
Selfweight: 204.9 lbs
Dist. Selfweight: 11.08 plf
Total Weight: 207.7 lbs
Beam Design 2022A461
7/3/2022 1
d = 13.500 in.
A = 3.500 x 13.500 = 47.25 in.2
Sx = (3.500)(13.500)2/6 = 106.31 in.3
Sy = (3.500)2(13.500)/6 = 27.56 in.3
Ix = (3.500)(13.500)3/12 = 717.61 in.4
Iy = (3.500)3(13.500)/12 = 48.23 in.4
7/3/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [47.25 x (222.00 + 3)] x (12 in./ft.)3 = 6.15 ft3
Volumespan = N[A x L] = 1 x [47.25 x 222.00] x (12 in./ft.)3 = 6.07 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.15 = 207.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.07 = 204.9 lbs
Distributed Self Weight (ws) = = 11.08 plf
207.5 plf
124.5 plf
  ws = 11.08 plf
18.50 ft.
18.25 ft.
18.75 ft.
3216.36 lbs
3216.36 lbs
7/3/2022 3
fb = = 1656.7 psi
 fb = 1656.7 psi < Fbx' = 2760.0 psi  (CSI = 0.60)   ➜  OK
7/3/2022 4
fv* = = 88.49 psi
 fv* = 88.49 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
fv = = 100.75 psi
 fv = 100.75 psi < Fvx' = 304.75 psi  (CSI = 0.33)   ➜  OK
7/3/2022 5
ΔLL = = 0.42 in.
(L/d)LL = 222.00 / 0.42 = 524
 ΔLL = 0.42 in = L/524 < L/360   ➜  OK
ΔTL = = 0.70 in.
(L/d)TL = 222.00 / 0.70 = 317
 ΔTL = 0.70 in = L/317 < L/240   ➜  OK
fc⊥ = = 306.3 psi
 fc⊥ = 306.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.47)   ➜  OK
7/3/2022 6
