Size: 3.5 x 16.5
Design Span (L): 20.00 ft.
Clear Span: 19.75 ft.
Total Span: 20.25 ft.
Live Load: 175 plf
Dead Load: 105 plf
Selfweight: 270.8 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 274.2 lbs
Beam Design 2022A460
7/3/2022 1
d = 16.500 in.
A = 3.500 x 16.500 = 57.75 in.2
Sx = (3.500)(16.500)2/6 = 158.81 in.3
Sy = (3.500)2(16.500)/6 = 33.69 in.3
Ix = (3.500)(16.500)3/12 = 1310.20 in.4
Iy = (3.500)3(16.500)/12 = 58.95 in.4
7/3/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (240.00 + 3)] x (12 in./ft.)3 = 8.12 ft3
Volumespan = N[A x L] = 1 x [57.75 x 240.00] x (12 in./ft.)3 = 8.02 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.12 = 274.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.02 = 270.8 lbs
175 plf
105 plf
  ws = 13.54 plf
19.75 ft.
20.25 ft.
2972.09 lbs
2972.09 lbs
7/3/2022 3
fb = = 1109.0 psi
 fb = 1109.0 psi < Fbx' = 2760.0 psi  (CSI = 0.40)   ➜  OK
7/3/2022 4
fv* = = 65.76 psi
 fv* = 65.76 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
fv = = 76.24 psi
 fv = 76.24 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
7/3/2022 5
ΔLL = = 0.27 in.
(L/d)LL = 240.00 / 0.27 = 898
 ΔLL = 0.27 in = L/898 < L/180   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 240.00 / 0.45 = 536
 ΔTL = 0.45 in = L/536 < L/120   ➜  OK
fc⊥ = = 283.1 psi
 fc⊥ = 283.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.44)   ➜  OK
7/3/2022 6
