Species: Western Cedars
Grade: WC No.2
Size: 4 x 6
Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 90 plf
Dead Load: 24 plf
Selfweight: 32.6 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 33.5 lbs
CM Wet Service Factor 1b 1 0.97 1c 0.67 0.9
Beam Design 2022A457
7/1/2022 1
WC No.2 700 425 155 425 650 1000000 370000 0.36
G = 0.36
7/1/2022 2
= 26.36 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (111.00 + 3)] x (12 in./ft.)3 = 1.27 ft3
Volumespan = N[A x L] = 1 x [19.25 x 111.00] x (12 in./ft.)3 = 1.24 ft3
Total Weight (WT) = ρw x Volumetotal = 26.36 x 1.27 = 33.5 lbs
Self Weight (WS) = ρw x Volumespan = 26.36 x 1.24 = 32.6 lbs
90 plf
24 plf
ws = 3.52 plf
9.25 ft.
9.00 ft.
9.50 ft.
558.24 lbs
558.24 lbs
7/1/2022 3
Fbx' = (700)(1.15)(1)(1)(1)(1.3)(1)(1) = 1046.5 psi
fb = = 854.8 psi
 fb = 854.8 psi < Fbx' = 1046.5 psi  (CSI = 0.82)   ➜  OK
7/1/2022 4
Fvx' = (155)(1.15)(0.97)(1)(1) = 172.90 psi
fv* = = 38.16 psi
 fv* = 38.16 psi < Fvx' = 172.90 psi  (CSI = 0.22)   ➜  OK
fv = = 42.35 psi
 fv = 42.35 psi < Fvx' = 172.90 psi  (CSI = 0.24)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1000000(0.9)(1)(1) = 900000 psi
7/1/2022 5
ΔLL = = 0.34 in.
(L/d)LL = 111.00 / 0.34 = 327
 ΔLL = 0.34 in = L/327 > L/360   ➜  NG
ΔTL = = 0.44 in.
(L/d)TL = 111.00 / 0.44 = 250
 ΔTL = 0.44 in = L/250 < L/240   ➜  OK
fc⊥ = = 53.2 psi
 fc⊥ = 53.2 psi < Fc⊥x' = 284.75 psi  (CSI = 0.19)   ➜  OK
7/1/2022 6
