Size: 3.125 x 12
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 524 plf
Dead Load: 131 plf
Selfweight: 120.9 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 123.1 lbs
Beam Design 2022A450
6/30/2022 1
b = 3.125 in.
6/30/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (165.00 + 3)] x (12 in./ft.)3 = 3.65 ft3
Volumespan = N[A x L] = 1 x [37.50 x 165.00] x (12 in./ft.)3 = 3.58 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.65 = 123.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.58 = 120.9 lbs
524 plf
131 plf
  ws = 8.79 plf
13.75 ft.
13.50 ft.
4646.54 lbs
4646.54 lbs
6/30/2022 3
fb = = 2510.0 psi
 fb = 2510.0 psi < Fbx' = 2760.0 psi  (CSI = 0.91)   ➜  OK
6/30/2022 4
fv* = = 155.99 psi
 fv* = 155.99 psi < Fvx' = 304.75 psi  (CSI = 0.51)   ➜  OK
fv = = 182.54 psi
 fv = 182.54 psi < Fvx' = 304.75 psi  (CSI = 0.60)   ➜  OK
6/30/2022 5
ΔLL = = 0.52 in.
(L/d)LL = 165.00 / 0.52 = 317
 ΔLL = 0.52 in = L/317 < L/180   ➜  OK
ΔTL = = 0.66 in.
(L/d)TL = 165.00 / 0.66 = 250
 ΔTL = 0.66 in = L/250 < L/120   ➜  OK
fc⊥ = = 495.6 psi
 fc⊥ = 495.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.76)   ➜  OK
6/30/2022 6
