Species: Western Cedars
Grade: WC No.2
Size: 4 x 16
Design Span (L): 21.58 ft.
Clear Span: 21.33 ft.
Total Span: 21.83 ft.
Live Load: 1967 lbs
Dead Load: 983 lbs
Selfweight: 414.8 lbs
Dist. Selfweight: 19.22 plf
Total Weight: 419.6 lbs
Notes: REAR PATIO BOTTOM CHORD
CM Wet Service Factor 1b 1 0.97 1c 0.67 0.9
Beam Design Ashby Signature - 3920 CR 152 2022A45
1/26/2022 1
d = 15.000 in.
WC No.2 700 425 155 425 650 1000000 370000 0.36
G = 0.36
1/26/2022 2
= 26.36 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [52.50 x (258.96 + 3)] x (12 in./ft.)3 = 15.92 ft3
Volumespan = N[A x L] = 2 x [52.50 x 258.96] x (12 in./ft.)3 = 15.74 ft3
Total Weight (WT) = ρw x Volumetotal = 26.36 x 15.92 = 419.6 lbs
Self Weight (WS) = ρw x Volumespan = 26.36 x 15.74 = 414.8 lbs
Distributed Self Weight (ws) = = 19.22 plf
1967 lbs
983 lbs
ws = 19.22 plf
21.58 ft.
21.33 ft.
21.83 ft.
1684.81 lbs
1684.81 lbs
1/26/2022 3
Fbx' = (700)(1.15)(1)(1)(1)(1)(1)(1) = 805.0 psi
fb = = 778.7 psi
 fb = 778.7 psi < Fbx' = 805.0 psi  (CSI = 0.97)   ➜  OK
1/26/2022 4
Fvx' = (155)(1.15)(0.97)(1)(1) = 172.90 psi
fv* = = 23.69 psi
 fv* = 23.69 psi < Fvx' = 172.90 psi  (CSI = 0.14)   ➜  OK
fv = = 24.03 psi
 fv = 24.03 psi < Fvx' = 172.90 psi  (CSI = 0.14)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1000000(0.9)(1)(1) = 900000 psi
1/26/2022 5
ΔLL =   =   = 0.40 in.
(L/d)LL = 258.96 / 0.40 = 645
 ΔLL = 0.40 in = L/645 < L/360   ➜  OK
ΔTL =   =   = 0.66 in.
(L/d)TL = 258.96 / 0.66 = 395
 ΔTL = 0.66 in = L/395 < L/240   ➜  OK
fc⊥ = = 80.2 psi
 fc⊥ = 80.2 psi < Fc⊥x' = 284.75 psi  (CSI = 0.28)   ➜  OK
1/26/2022 6
