Size: 3.5 x 12
Design Span (L): 18.50 ft.
Clear Span: 18.25 ft.
Total Span: 18.75 ft.
Live Load: 3450 lbs
Dead Load: 810 lbs
Selfweight: 182.2 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 184.6 lbs
Beam Design 2022A449
6/30/2022 1
6/30/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (222.00 + 3)] x (12 in./ft.)3 = 5.47 ft3
Volumespan = N[A x L] = 1 x [42.00 x 222.00] x (12 in./ft.)3 = 5.40 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.47 = 184.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.40 = 182.2 lbs
3450 lbs
810 lbs
  ws = 9.85 plf
18.50 ft.
18.25 ft.
18.75 ft.
2222.32 lbs
2222.32 lbs
6/30/2022 3
fb = = 2874.8 psi
 fb = 2874.8 psi > Fbx' = 2760.0 psi  (CSI = 1.04)   ➜  NG
6/30/2022 4
fv* = = 78.97 psi
 fv* = 78.97 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
fv = = 79.32 psi
 fv = 79.32 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
6/30/2022 5
ΔLL =   =   = 0.87 in.
(L/d)LL = 222.00 / 0.87 = 256
 ΔLL = 0.87 in = L/256 > L/360   ➜  NG
ΔTL =   =   = 1.10 in.
(L/d)TL = 222.00 / 1.10 = 202
 ΔTL = 1.10 in = L/202 > L/240   ➜  NG
fc⊥ = = 211.6 psi
 fc⊥ = 211.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.33)   ➜  OK
6/30/2022 6
