Grade: 24F-V8 1.8E DF/DF
Size: 12.25 x 60
Design Span (L): 84.00 ft.
Clear Span: 83.00 ft.
Total Span: 85.00 ft.
Bearing (lb): 12 in.
Live Load: 1240 plf
Dead Load: 200 plf
Selfweight: 28950.2 lbs
Dist. Selfweight: 344.65 plf
Total Weight: 29294.9 lbs
CV Volume Factor 0.679b - - - - -
Beam Design Randy Ludwar 736 Main Street, Box 614 Geno
6/29/2022 1
b = 12.250 in.
d = 60.000 in.
A = 12.250 x 60.000 = 735.00 in.2
Sx = (12.250)(60.000)2/6 = 7350.00 in.3
Sy = (12.250)2(60.000)/6 = 1500.63 in.3
Ix = (12.250)(60.000)3/12 = 220500.00 in.4
Iy = (12.250)3(60.000)/12 = 9191.33 in.4
6/29/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [735.00 x (1008.00 + 12)] x (12 in./ft.)3 = 867.71 ft3
Volumespan = N[A x L] = 2 x [735.00 x 1008.00] x (12 in./ft.)3 = 857.50 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 867.71 = 29294.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 857.50 = 28950.2 lbs
Distributed Self Weight (ws) = = 344.65 plf
1240 plf
200 plf
  ws = 344.65 plf
84.00 ft.
83.00 ft.
85.00 ft.
75847.43 lbs
75847.43 lbs
6/29/2022 3
CV = = 0.679
CV = 0.679 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.679) = 1874.8 psi
fb = = 1284.9 psi
 fb = 1284.9 psi < Fbx' = 1874.8 psi  (CSI = 0.69)   ➜  OK
6/29/2022 4
fv* = = 67.38 psi
 fv* = 67.38 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
fv = = 76.48 psi
 fv = 76.48 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
6/29/2022 5
ΔLL = = 1.75 in.
(L/d)LL = 1008.00 / 1.75 = 576
 ΔLL = 1.75 in = L/576 < L/360   ➜  OK
ΔTL = = 2.52 in.
(L/d)TL = 1008.00 / 2.52 = 400
 ΔTL = 2.52 in = L/400 < L/240   ➜  OK
fc⊥ = = 258.0 psi
 fc⊥ = 258.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.40)   ➜  OK
6/29/2022 6
