Grade: SPF SS
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 611 plf
Dead Load: 221 plf
Selfweight: 52.9 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 54.6 lbs
Beam Design 10300 Eve Rd 2022A444
6/28/2022 1
6/28/2022 2
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.88 = 54.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.82 = 52.9 lbs
611 plf
221 plf
ws = 6.82 plf
7.75 ft.
7.50 ft.
3355.28 lbs
3355.28 lbs
6/28/2022 3
fb = = 1194.2 psi
 fb = 1194.2 psi < Fbx' = 1437.5 psi  (CSI = 0.83)   ➜  OK
6/28/2022 4
fv* = = 109.51 psi
 fv* = 109.51 psi < Fvx' = 155.25 psi  (CSI = 0.71)   ➜  OK
fv = = 144.46 psi
 fv = 144.46 psi < Fvx' = 155.25 psi  (CSI = 0.93)   ➜  OK
6/28/2022 5
ΔLL = = 0.09 in.
(L/d)LL = 93.00 / 0.09 = 1001
 ΔLL = 0.09 in = L/1001 < L/180   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 93.00 / 0.13 = 729
 ΔTL = 0.13 in = L/729 < L/120   ➜  OK
fc⊥ = = 372.8 psi
 fc⊥ = 372.8 psi < Fc⊥x' = 425.00 psi  (CSI = 0.88)   ➜  OK
6/28/2022 6
