Grade: SP DSS
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 611 plf
Dead Load: 221 plf
Selfweight: 67.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 70.0 lbs
Beam Design 10300 Eve Rd 2022A443
6/28/2022 1
6/28/2022 2
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.88 = 70.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.82 = 67.8 lbs
611 plf
221 plf
ws = 8.75 plf
7.75 ft.
7.50 ft.
3363.00 lbs
3363.00 lbs
6/28/2022 3
fb = = 1197.0 psi
 fb = 1197.0 psi < Fbx' = 2070.0 psi  (CSI = 0.58)   ➜  OK
6/28/2022 4
fv* = = 109.76 psi
 fv* = 109.76 psi < Fvx' = 201.25 psi  (CSI = 0.55)   ➜  OK
fv = = 144.80 psi
 fv = 144.80 psi < Fvx' = 201.25 psi  (CSI = 0.72)   ➜  OK
6/28/2022 5
ΔLL = = 0.07 in.
(L/d)LL = 93.00 / 0.07 = 1268
 ΔLL = 0.07 in = L/1268 < L/180   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 93.00 / 0.10 = 922
 ΔTL = 0.10 in = L/922 < L/120   ➜  OK
fc⊥ = = 373.7 psi
 fc⊥ = 373.7 psi < Fc⊥x' = 660.00 psi  (CSI = 0.57)   ➜  OK
6/28/2022 6
