Beam Design - SCHANK
Grade: SPF SS
Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 624 plf
Dead Load: 272 plf
Selfweight: 23.1 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 24.2 lbs
Notes: HEADERS
Beam Design 2022A441
6/27/2022 1
6/27/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (63.00 + 3)] x (12 in./ft.)3 = 0.83 ft3
Volumespan = N[A x L] = 2 x [10.88 x 63.00] x (12 in./ft.)3 = 0.79 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.83 = 24.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.79 = 23.1 lbs
624 plf
272 plf
ws = 4.39 plf
5.25 ft.
5.00 ft.
5.50 ft.
2476.09 lbs
2476.09 lbs
6/27/2022 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.2)(1)(1) = 1725.0 psi
fb = = 1416.4 psi
 fb = 1416.4 psi < Fbx' = 1725.0 psi  (CSI = 0.82)   ➜  OK
6/27/2022 4
fv* = = 125.49 psi
 fv* = 125.49 psi < Fvx' = 155.25 psi  (CSI = 0.81)   ➜  OK
fv = = 163.00 psi
 fv = 163.00 psi > Fvx' = 155.25 psi  (CSI = 1.05)   ➜  NG
6/27/2022 5
ΔLL = = 0.07 in.
(L/d)LL = 63.00 / 0.07 = 844
 ΔLL = 0.07 in = L/844 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 63.00 / 0.11 = 585
 ΔTL = 0.11 in = L/585 < L/240   ➜  OK
fc⊥ = = 275.1 psi
 fc⊥ = 275.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.65)   ➜  OK
6/27/2022 6
