Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Live Load: 852 plf
Dead Load: 277 plf
Selfweight: 94.1 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 96.2 lbs
Beam Design 2022A436
6/22/2022 1
6/22/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (129.00 + 3)] x (12 in./ft.)3 = 2.58 ft3
Volumespan = N[A x L] = 2 x [16.88 x 129.00] x (12 in./ft.)3 = 2.52 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.58 = 96.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.52 = 94.1 lbs
852 plf
277 plf
ws = 8.75 plf
10.75 ft.
10.50 ft.
11.00 ft.
6257.62 lbs
6257.62 lbs
6/22/2022 3
fb = = 3116.6 psi
 fb = 3116.6 psi > Fbx' = 862.5 psi  (CSI = 3.61)   ➜  NG
6/22/2022 4
fv* = = 224.39 psi
 fv* = 224.39 psi > Fvx' = 201.25 psi  (CSI = 1.11)   ➜  NG
fv = = 271.80 psi
 fv = 271.80 psi > Fvx' = 201.25 psi  (CSI = 1.35)   ➜  NG
6/22/2022 5
ΔLL = = 0.51 in.
(L/d)LL = 129.00 / 0.51 = 251
 ΔLL = 0.51 in = L/251 < L/180   ➜  OK
ΔTL = = 0.69 in.
(L/d)TL = 129.00 / 0.69 = 188
 ΔTL = 0.69 in = L/188 < L/120   ➜  OK
fc⊥ = = 695.3 psi
 fc⊥ = 695.3 psi > Fc⊥x' = 565.00 psi  (CSI = 1.23)   ➜  NG
6/22/2022 6
