Grade: DF No.1 & Btr
Design Span (L): 14.50 ft.
Clear Span: 14.00 ft.
Total Span: 15.00 ft.
Live Load: 225 plf
Dead Load: 57 plf
Selfweight: 143.4 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 148.3 lbs
Beam Design Steve Winiarski 7096 E Geddes Place, Centennial, CO 2022A435
6/22/2022 1
6/22/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (174.00 + 6)] x (12 in./ft.)3 = 4.34 ft3
Volumespan = N[A x L] = 3 x [13.88 x 174.00] x (12 in./ft.)3 = 4.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.34 = 148.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.19 = 143.4 lbs
225 plf
57 plf
ws = 9.89 plf
14.50 ft.
15.00 ft.
2189.15 lbs
2189.15 lbs
6/22/2022 3
Fbx' = (1200)(1.15)(1)(1)(1)(1.1)(1)(1) = 1518.0 psi
fb = = 1434.5 psi
 fb = 1434.5 psi < Fbx' = 1518.0 psi  (CSI = 0.94)   ➜  OK
6/22/2022 4
fv* = = 68.15 psi
 fv* = 68.15 psi < Fvx' = 207.00 psi  (CSI = 0.33)   ➜  OK
fv = = 76.26 psi
 fv = 76.26 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
6/22/2022 5
ΔLL = = 0.42 in.
(L/d)LL = 174.00 / 0.42 = 415
 ΔLL = 0.42 in = L/415 < L/180   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 174.00 / 0.54 = 320
 ΔTL = 0.54 in = L/320 < L/120   ➜  OK
fc⊥ = = 81.1 psi
 fc⊥ = 81.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
6/22/2022 6
