Design Span (L): 4.33 ft.
Clear Span: 4.00 ft.
Total Span: 4.67 ft.
Bearing (lb): 4 in.
Live Load: 825 plf
Dead Load: 300 plf
Selfweight: 22.4 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 24.1 lbs
Beam Design Steve Winiarski 7096 E Geddes Place, Centennial, CO 2022A431
6/22/2022 1
6/22/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (52.00 + 4)] x (12 in./ft.)3 = 0.70 ft3
Volumespan = N[A x L] = 2 x [10.88 x 52.00] x (12 in./ft.)3 = 0.65 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.70 = 24.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.65 = 22.4 lbs
825 plf
300 plf
ws = 5.17 plf
4.33 ft.
4.00 ft.
4.67 ft.
2636.87 lbs
2636.87 lbs
6/22/2022 3
fb = = 1211.1 psi
 fb = 1211.1 psi < Fbx' = 1242.0 psi  (CSI = 0.98)   ➜  OK
6/22/2022 4
fv* = = 121.77 psi
 fv* = 121.77 psi < Fvx' = 207.00 psi  (CSI = 0.59)   ➜  OK
fv = = 168.86 psi
 fv = 168.86 psi < Fvx' = 207.00 psi  (CSI = 0.82)   ➜  OK
6/22/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 52.00 / 0.04 = 1211
 ΔLL = 0.04 in = L/1211 < L/180   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 52.00 / 0.06 = 884
 ΔTL = 0.06 in = L/884 < L/120   ➜  OK
fc⊥ = = 219.7 psi
 fc⊥ = 219.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.35)   ➜  OK
6/22/2022 6
