Beam Design - The Winiarskis
Design Span (L): 14.33 ft.
Clear Span: 14.00 ft.
Total Span: 14.67 ft.
Bearing (lb): 4 in.
Live Load: 80 plf
Selfweight: 114.9 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 117.6 lbs
Beam Design Steve Winiarski 7096 E Geddes Place, Centennial, CO 2022A430
6/22/2022 1
6/22/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (172.00 + 4)] x (12 in./ft.)3 = 3.44 ft3
Volumespan = N[A x L] = 2 x [16.88 x 172.00] x (12 in./ft.)3 = 3.36 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.44 = 117.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.36 = 114.9 lbs
80 plf
ws = 8.02 plf
14.33 ft.
14.67 ft.
1195.43 lbs
1195.43 lbs
6/22/2022 3
fb = = 793.8 psi
 fb = 793.8 psi < Fbx' = 1035.0 psi  (CSI = 0.77)   ➜  OK
6/22/2022 4
fv* = = 45.13 psi
 fv* = 45.13 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
fv = = 51.92 psi
 fv = 51.92 psi < Fvx' = 207.00 psi  (CSI = 0.25)   ➜  OK
6/22/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 172.00 / 0.13 = 1289
 ΔLL = 0.13 in = L/1289 < L/180   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 172.00 / 0.27 = 633
 ΔTL = 0.27 in = L/633 < L/120   ➜  OK
fc⊥ = = 99.6 psi
 fc⊥ = 99.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
6/22/2022 6
