Beam Design - LEDGER - Piggott Loft
Grade: SP No.1
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 160 plf
Dead Load: 40 plf
Selfweight: 55.0 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 56.4 lbs
Beam Design Mitch Vogt Waukon, IA 001
6/22/2022 1
SP No.1 1250 800 175 565 1500 1600000 580000 0.55
6/22/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (117.00 + 3)] x (12 in./ft.)3 = 1.51 ft3
Volumespan = N[A x L] = 2 x [10.88 x 117.00] x (12 in./ft.)3 = 1.47 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.51 = 56.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.47 = 55.0 lbs
160 plf
40 plf
ws = 5.64 plf
9.75 ft.
9.50 ft.
10.00 ft.
1028.19 lbs
1028.19 lbs
6/22/2022 3
Fbx' = (1250)(1.00)(1)(1)(1)(1)(1)(1) = 1250.0 psi
fb = = 1115.7 psi
 fb = 1115.7 psi < Fbx' = 1250.0 psi  (CSI = 0.89)   ➜  OK
6/22/2022 4
fv* = = 60.57 psi
 fv* = 60.57 psi < Fvx' = 175.00 psi  (CSI = 0.35)   ➜  OK
fv = = 69.14 psi
 fv = 69.14 psi < Fvx' = 175.00 psi  (CSI = 0.40)   ➜  OK
6/22/2022 5
ΔLL = = 0.21 in.
(L/d)LL = 117.00 / 0.21 = 548
 ΔLL = 0.21 in = L/548 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 117.00 / 0.27 = 427
 ΔTL = 0.27 in = L/427 < L/240   ➜  OK
fc⊥ = = 114.2 psi
 fc⊥ = 114.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.20)   ➜  OK
6/22/2022 6
