Beam Design - JOISTS - Piggott Loft
Grade: SP No.1
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 54 plf
Dead Load: 14 plf
Selfweight: 16.6 lbs
Dist. Selfweight: 2.14 plf
Total Weight: 17.1 lbs
CL Beam Stability Factor 0.891 - - - - -
Beam Design Mitch Vogt Waukon, IA 001
6/21/2022 1
SP No.1 1350 875 175 565 1550 1600000 580000 0.55
6/21/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (93.00 + 3)] x (12 in./ft.)3 = 0.46 ft3
Volumespan = N[A x L] = 1 x [8.25 x 93.00] x (12 in./ft.)3 = 0.44 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.46 = 17.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.44 = 16.6 lbs
Distributed Self Weight (ws) = = 2.14 plf
54 plf
14 plf
ws = 2.14 plf
7.75 ft.
7.50 ft.
280.55 lbs
280.55 lbs
6/21/2022 3
lu = Unbraced Length = 7.750 ft.
lu/d = = 16.91
le = 1.63lu + 3d = 1.63(93.0) + 3(5.5) = 168.09 in. = 14.01 ft.  (NDS Table 3.3.3)
Rb = = 20.27
 Rb = 20.27 < 50   ➜  OK
6/21/2022 4
FbE = = 1693.90 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1350)(1.00)(1)(1)(1)(1)(1) = 1350.00 psi
CL =   = 0.891
Fbx' = (1350)(1.00)(1)(1)(0.891)(1)(1)(1) = 1202.7 psi
fb = = 835.6 psi
 fb = 835.6 psi < Fbx' = 1202.7 psi  (CSI = 0.69)   ➜  OK
fv* = = 43.57 psi
 fv* = 43.57 psi < Fvx' = 175.00 psi  (CSI = 0.25)   ➜  OK
fv = = 49.42 psi
 fv = 49.42 psi < Fvx' = 175.00 psi  (CSI = 0.28)   ➜  OK
6/21/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 93.00 / 0.13 = 706
 ΔLL = 0.13 in = L/706 < L/360   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 93.00 / 0.17 = 544
 ΔTL = 0.17 in = L/544 < L/240   ➜  OK
fc⊥ = = 62.3 psi
 fc⊥ = 62.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.11)   ➜  OK
6/21/2022 6
