Beam Design - LEDGER - Piggott Loft
Grade: SP No.1
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 160 plf
Dead Load: 40 plf
Selfweight: 42.7 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 43.7 lbs
Beam Design Mitch Vogt Waukon, IA 001
6/21/2022 1
6/21/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (117.00 + 3)] x (12 in./ft.)3 = 1.17 ft3
Volumespan = N[A x L] = 1 x [16.88 x 117.00] x (12 in./ft.)3 = 1.14 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.17 = 43.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.14 = 42.7 lbs
160 plf
40 plf
ws = 4.37 plf
9.75 ft.
9.50 ft.
10.00 ft.
1021.87 lbs
1021.87 lbs
6/21/2022 3
fb = = 921.0 psi
 fb = 921.0 psi < Fbx' = 1000.0 psi  (CSI = 0.92)   ➜  OK
6/21/2022 4
fv* = = 71.53 psi
 fv* = 71.53 psi < Fvx' = 175.00 psi  (CSI = 0.41)   ➜  OK
fv = = 88.56 psi
 fv = 88.56 psi < Fvx' = 175.00 psi  (CSI = 0.51)   ➜  OK
6/21/2022 5
ΔLL = = 0.11 in.
(L/d)LL = 117.00 / 0.11 = 1024
 ΔLL = 0.11 in = L/1024 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 117.00 / 0.15 = 802
 ΔTL = 0.15 in = L/802 < L/240   ➜  OK
fc⊥ = = 227.1 psi
 fc⊥ = 227.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.40)   ➜  OK
6/21/2022 6
