Beam Design - WEST MAIN SPAN - Piggott Loft
Grade: SP No.1
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 200 plf
Dead Load: 50 plf
Selfweight: 180.5 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 183.7 lbs
Beam Design Mitch Vogt Waukon, IA 001
6/21/2022 1
6/21/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (165.00 + 3)] x (12 in./ft.)3 = 4.92 ft3
Volumespan = N[A x L] = 3 x [16.88 x 165.00] x (12 in./ft.)3 = 4.83 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.92 = 183.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.83 = 180.5 lbs
200 plf
50 plf
ws = 13.12 plf
13.75 ft.
13.50 ft.
1841.87 lbs
1841.87 lbs
6/21/2022 3
fb = = 786.1 psi
 fb = 786.1 psi < Fbx' = 1000.0 psi  (CSI = 0.79)   ➜  OK
6/21/2022 4
fv* = = 46.29 psi
 fv* = 46.29 psi < Fvx' = 175.00 psi  (CSI = 0.26)   ➜  OK
fv = = 53.60 psi
 fv = 53.60 psi < Fvx' = 175.00 psi  (CSI = 0.31)   ➜  OK
6/21/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 165.00 / 0.19 = 876
 ΔLL = 0.19 in = L/876 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 165.00 / 0.25 = 666
 ΔTL = 0.25 in = L/666 < L/240   ➜  OK
fc⊥ = = 136.4 psi
 fc⊥ = 136.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.24)   ➜  OK
6/21/2022 6
