Grade: SP No.1
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 200 plf
Dead Load: 50 plf
Selfweight: 148.4 lbs
Dist. Selfweight: 10.79 plf
Total Weight: 151.1 lbs
Beam Design 2022A420
6/21/2022 1
6/21/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (165.00 + 3)] x (12 in./ft.)3 = 4.05 ft3
Volumespan = N[A x L] = 3 x [13.88 x 165.00] x (12 in./ft.)3 = 3.97 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.05 = 151.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.97 = 148.4 lbs
Distributed Self Weight (ws) = = 10.79 plf
200 plf
50 plf
ws = 10.79 plf
13.75 ft.
13.50 ft.
1825.53 lbs
1825.53 lbs
6/21/2022 3
Fbx' = (1050)(1.00)(1)(1)(1)(1)(1)(1) = 1050.0 psi
fb = = 1152.5 psi
 fb = 1152.5 psi > Fbx' = 1050.0 psi  (CSI = 1.10)   ➜  NG
6/21/2022 4
fv* = = 57.37 psi
 fv* = 57.37 psi < Fvx' = 175.00 psi  (CSI = 0.33)   ➜  OK
fv = = 64.61 psi
 fv = 64.61 psi < Fvx' = 175.00 psi  (CSI = 0.37)   ➜  OK
6/21/2022 5
ΔLL = = 0.34 in.
(L/d)LL = 165.00 / 0.34 = 487
 ΔLL = 0.34 in = L/487 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 165.00 / 0.44 = 374
 ΔTL = 0.44 in = L/374 < L/240   ➜  OK
fc⊥ = = 135.2 psi
 fc⊥ = 135.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.24)   ➜  OK
6/21/2022 6
