Grade: DF SS
Design Span (L): 20.45 ft.
Clear Span: 20.20 ft.
Total Span: 20.70 ft.
Live Load: 150 plf
Dead Load: 60 plf
Selfweight: 245.9 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 248.9 lbs
Beam Design 2022A42
1/25/2022 1
Beam Design 2022A42
1/25/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (245.40 + 3)] x (12 in./ft.)3 = 7.28 ft3
Volumespan = N[A x L] = 3 x [16.88 x 245.40] x (12 in./ft.)3 = 7.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.28 = 248.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.19 = 245.9 lbs
150 plf
60 plf
ws = 12.02 plf
20.45 ft.
20.20 ft.
20.70 ft.
2297.96 lbs
2297.96 lbs
Beam Design 2022A42
1/25/2022 3
Fbx' = (1500)(1.00)(1)(1)(1)(1)(1)(1) = 1500.0 psi
fb = = 1467.3 psi
 fb = 1467.3 psi < Fbx' = 1500.0 psi  (CSI = 0.98)   ➜  OK
Beam Design 2022A42
1/25/2022 4
fv* = = 61.10 psi
 fv* = 61.10 psi < Fvx' = 180.00 psi  (CSI = 0.34)   ➜  OK
fv = = 67.27 psi
 fv = 67.27 psi < Fvx' = 180.00 psi  (CSI = 0.37)   ➜  OK
Beam Design 2022A42
1/25/2022 5
ΔLL = = 0.58 in.
(L/d)LL = 245.40 / 0.58 = 422
 ΔLL = 0.58 in = L/422 < L/240   ➜  OK
ΔTL = = 0.86 in.
(L/d)TL = 245.40 / 0.86 = 285
 ΔTL = 0.86 in = L/285 < L/180   ➜  OK
fc⊥ = = 170.2 psi
 fc⊥ = 170.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.27)   ➜  OK
Beam Design 2022A42
1/25/2022 6
