Beam Design - LEDGER - Piggott Loft
Grade: SP No.1
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 120 plf
Dead Load: 30 plf
Selfweight: 35.1 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 36.0 lbs
Beam Design Mitch Vogt Waukon, IA 001
6/21/2022 1
6/21/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 0.96 ft3
Volumespan = N[A x L] = 1 x [13.88 x 117.00] x (12 in./ft.)3 = 0.94 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.96 = 36.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.94 = 35.1 lbs
120 plf
30 plf
ws = 3.60 plf
9.75 ft.
9.50 ft.
10.00 ft.
767.98 lbs
767.98 lbs
6/21/2022 3
Fbx' = (1050)(1.15)(1)(1)(1)(1)(1)(1) = 1207.5 psi
fb = = 1023.9 psi
 fb = 1023.9 psi < Fbx' = 1207.5 psi  (CSI = 0.85)   ➜  OK
6/21/2022 4
fv* = = 68.15 psi
 fv* = 68.15 psi < Fvx' = 201.25 psi  (CSI = 0.34)   ➜  OK
fv = = 80.95 psi
 fv = 80.95 psi < Fvx' = 201.25 psi  (CSI = 0.40)   ➜  OK
6/21/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 117.00 / 0.15 = 759
 ΔLL = 0.15 in = L/759 < L/360   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 117.00 / 0.20 = 593
 ΔTL = 0.20 in = L/593 < L/240   ➜  OK
fc⊥ = = 170.7 psi
 fc⊥ = 170.7 psi < Fc⊥x' = 565.00 psi  (CSI = 0.30)   ➜  OK
6/21/2022 6
