Grade: SPF No.1
Design Span (L): 5.00 ft.
Clear Span: 4.75 ft.
Total Span: 5.25 ft.
Live Load: 600 plf
Dead Load: 100 plf
Selfweight: 22.0 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 23.1 lbs
Orientation: Horizontal
Incised Lumber: Yes
Beam Design 2022A415
6/20/2022 1
SPF No.1 875 450 135 425 1150 1400000 510000 0.42
6/20/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (60.00 + 3)] x (12 in./ft.)3 = 0.79 ft3
Volumespan = N[A x L] = 2 x [10.88 x 60.00] x (12 in./ft.)3 = 0.76 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.79 = 23.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.76 = 22.0 lbs
600 plf
ws = 4.39 plf
5.00 ft.
4.75 ft.
5.25 ft.
1849.04 lbs
1849.04 lbs
6/20/2022 3
Fby' = (875)(1.15)(1)(1)(1)(1.2)(1.15)(0.8)(1.15) = 1277.5 psi
fb = = 4857.9 psi
 fb = 4857.9 psi > Fby' = 1277.5 psi  (CSI = 3.80)   ➜  NG
6/20/2022 4
Fvy' = (135)(1.15)(1)(1)(0.8) = 124.20 psi
fv* = = 115.38 psi
 fv* = 115.38 psi < Fvy' = 124.20 psi  (CSI = 0.93)   ➜  OK
fv = = 121.45 psi
 fv = 121.45 psi < Fvy' = 124.20 psi  (CSI = 0.98)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(1)(1)(0.95) = 1330000 psi
6/20/2022 5
ΔLL = = 1.56 in.
(L/d)LL = 60.00 / 1.56 = 39
 ΔLL = 1.56 in = L/39 > L/180   ➜  NG
ΔTL = = 1.83 in.
(L/d)TL = 60.00 / 1.83 = 33
 ΔTL = 1.83 in = L/33 > L/120   ➜  NG
Fc⊥y' = (425)(1)(1)(1) = 425.00 psi
Ab = d x lb = 7.25 x 3 = 21.75 in2
fc⊥ = = 42.5 psi
 fc⊥ = 42.5 psi < Fc⊥y' = 425.00 psi  (CSI = 0.10)   ➜  OK
6/20/2022 6
