Size: 2.5 x 12
Design Span (L): 21.58 ft.
Clear Span: 21.17 ft.
Total Span: 22.00 ft.
Bearing (lb): 5 in.
Selfweight: 319.0 lbs
Dist. Selfweight: 14.78 plf
Total Weight: 325.1 lbs
Beam Design 2022A411
6/18/2022 1
b = 2.500 in.
A = 2.500 x 12.000 = 30.00 in.2
Sx = (2.500)(12.000)2/6 = 60.00 in.3
Sy = (2.500)2(12.000)/6 = 12.50 in.3
Ix = (2.500)(12.000)3/12 = 360.00 in.4
Iy = (2.500)3(12.000)/12 = 15.63 in.4
6/18/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [30.00 x (259.00 + 5)] x (12 in./ft.)3 = 9.17 ft3
Volumespan = N[A x L] = 2 x [30.00 x 259.00] x (12 in./ft.)3 = 8.99 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 9.17 = 325.1 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 8.99 = 319.0 lbs
Distributed Self Weight (ws) = = 14.78 plf
  ws = 14.78 plf
21.58 ft.
21.17 ft.
22.00 ft.
2087.53 lbs
2087.53 lbs
6/18/2022 3
fb = = 1105.0 psi
 fb = 1105.0 psi < Fbx' = 2208.0 psi  (CSI = 0.50)   ➜  OK
6/18/2022 4
fv* = = 46.46 psi
 fv* = 46.46 psi < Fvx' = 266.66 psi  (CSI = 0.17)   ➜  OK
fv = = 51.20 psi
 fv = 51.20 psi < Fvx' = 266.66 psi  (CSI = 0.19)   ➜  OK
6/18/2022 5
ΔLL = = 0.45 in.
(L/d)LL = 259.00 / 0.45 = 573
 ΔLL = 0.45 in = L/573 < L/360   ➜  OK
ΔTL = = 0.86 in.
(L/d)TL = 259.00 / 0.86 = 302
 ΔTL = 0.86 in = L/302 < L/240   ➜  OK
Ab = b x lb = 2.5 x 5 = 12.50 in2
fc⊥ = = 83.5 psi
 fc⊥ = 83.5 psi < Fc⊥x' = 344.50 psi  (CSI = 0.24)   ➜  OK
6/18/2022 6
