Live Load: 360 plf
Dead Load: 120 plf
Selfweight: 116.2 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 118.6 lbs
Beam Design 2022A40
1/21/2022 1
Beam Design 2022A40
1/21/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 141.00] x (12 in./ft.)3 = 3.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.47 = 118.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.40 = 116.2 lbs
360 plf
120 plf
ws = 9.89 plf
2939.32 lbs
2939.32 lbs
Beam Design 2022A40
1/21/2022 3
fb = = 1581.0 psi
 fb = 1581.0 psi > Fbx' = 990.0 psi  (CSI = 1.60)   ➜  NG
Beam Design 2022A40
1/21/2022 4
fv* = = 90.11 psi
 fv* = 90.11 psi < Fvx' = 180.00 psi  (CSI = 0.50)   ➜  OK
fv = = 103.71 psi
 fv = 103.71 psi < Fvx' = 180.00 psi  (CSI = 0.58)   ➜  OK
Beam Design 2022A40
1/21/2022 5
ΔLL = = 0.33 in.
(L/d)LL = 141.00 / 0.33 = 434
 ΔLL = 0.33 in = L/434 < L/180   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 141.00 / 0.44 = 319
 ΔTL = 0.44 in = L/319 < L/120   ➜  OK
fc⊥ = = 217.7 psi
 fc⊥ = 217.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.35)   ➜  OK
Beam Design 2022A40
1/21/2022 6
