Grade: DF No.1
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Quantity (N): 4
Live Load: 274 plf
Dead Load: 121 plf
Selfweight: 228.5 lbs
Dist. Selfweight: 16.03 plf
Total Weight: 232.5 lbs
Beam Design 2022A4
1/4/2022 1
Beam Design 2022A4
1/4/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (171.00 + 3)] x (12 in./ft.)3 = 6.80 ft3
Volumespan = N[A x L] = 4 x [16.88 x 171.00] x (12 in./ft.)3 = 6.68 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 6.80 = 232.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 6.68 = 228.5 lbs
274 plf
121 plf
ws = 16.03 plf
14.25 ft.
14.50 ft.
2979.99 lbs
2979.99 lbs
Beam Design 2022A4
1/4/2022 3
fb = = 989.2 psi
 fb = 989.2 psi < Fbx' = 1000.0 psi  (CSI = 0.99)   ➜  OK
Beam Design 2022A4
1/4/2022 4
fv* = = 56.52 psi
 fv* = 56.52 psi < Fvx' = 180.00 psi  (CSI = 0.31)   ➜  OK
fv = = 65.08 psi
 fv = 65.08 psi < Fvx' = 180.00 psi  (CSI = 0.36)   ➜  OK
Beam Design 2022A4
1/4/2022 5
ΔLL = = 0.21 in.
(L/d)LL = 171.00 / 0.21 = 814
 ΔLL = 0.21 in = L/814 < L/360   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 171.00 / 0.32 = 543
 ΔTL = 0.32 in = L/543 < L/240   ➜  OK
fc⊥ = = 165.6 psi
 fc⊥ = 165.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.26)   ➜  OK
Beam Design 2022A4
1/4/2022 6
