Grade: DF No.1
Size: 4 x 12
Design Span (L): 18.79 ft.
Clear Span: 18.58 ft.
Total Span: 19.00 ft.
Bearing (lb): 2.5 in.
Live Load: 0 plf
Dead Load: 32.8 plf
Selfweight: 175.8 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 177.7 lbs
Incised Lumber: Yes
CL Beam Stability Factor 0.968 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A398
6/17/2022 1
6/17/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (225.50 + 2.5)] x (12 in./ft.)3 = 5.20 ft3
Volumespan = N[A x L] = 1 x [39.38 x 225.50] x (12 in./ft.)3 = 5.14 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.20 = 177.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.14 = 175.8 lbs
0 plf
32.8 plf
ws = 9.35 plf
18.79 ft.
18.58 ft.
19.00 ft.
400.46 lbs
400.46 lbs
6/17/2022 3
lu = Unbraced Length = 18.792 ft.
lu/d = = 20.04
le = 1.63lu + 3d = 1.63(225.5) + 3(11.25) = 401.32 in. = 33.44 ft.  (NDS Table 3.3.3)
Rb = = 19.20
 Rb = 19.20 < 50   ➜  OK
6/17/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(1)(1)(0.95) = 589000 psi
FbE = = 1917.73 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(0.9)(1)(1)(1.1)(0.8)(1) = 792.00 psi
CL =   = 0.968
Fbx' = (1000)(0.9)(1)(1)(0.968)(1.1)(0.8)(1) = 766.5 psi
fb = = 302.4 psi
 fb = 302.4 psi < Fbx' = 766.5 psi  (CSI = 0.39)   ➜  OK
Fvx' = (180)(0.9)(1)(1)(0.8) = 129.60 psi
fv* = = 13.58 psi
 fv* = 13.58 psi < Fvx' = 129.60 psi  (CSI = 0.10)   ➜  OK
fv = = 15.09 psi
 fv = 15.09 psi < Fvx' = 129.60 psi  (CSI = 0.12)   ➜  OK
6/17/2022 5
Ex' = Ex(CM)(Ct)(Ci) = 1700000(1)(1)(0.95) = 1615000 psi
ΔLL = = 0.00 in.
(L/d)LL = 225.50 / 0.00 = ∞
ΔTL = = 0.18 in.
(L/d)TL = 225.50 / 0.18 = 1279
 ΔTL = 0.18 in = L/1279 < L/120   ➜  OK
Ab = b x lb = 3.5 x 2.5 = 8.75 in2
fc⊥ = = 45.8 psi
 fc⊥ = 45.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
6/17/2022 6
