Grade: DF No.1
Size: 4 x 12
Design Span (L): 18.79 ft.
Clear Span: 18.58 ft.
Total Span: 19.00 ft.
Bearing (lb): 2.5 in.
Live Load: 33 plf
Dead Load: 9.5 plf
Selfweight: 175.8 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 177.7 lbs
Lateral Support: 4' o/c
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A396
6/17/2022 1
6/17/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (225.50 + 2.5)] x (12 in./ft.)3 = 5.20 ft3
Volumespan = N[A x L] = 1 x [39.38 x 225.50] x (12 in./ft.)3 = 5.14 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.20 = 177.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.14 = 175.8 lbs
33 plf
9.5 plf
ws = 9.35 plf
18.79 ft.
18.58 ft.
19.00 ft.
492.61 lbs
492.61 lbs
6/17/2022 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.27
Rb = = 9.53
 Rb = 9.53 < 50   ➜  OK
6/17/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(1)(1)(1) = 620000 psi
FbE = = 8193.10 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.00)(1)(1)(1.1)(1)(1) = 1100.00 psi
CL =   = 0.992
Fbx' = (1000)(1.00)(1)(1)(0.992)(1.1)(1)(1) = 1091.6 psi
fb = = 372.0 psi
 fb = 372.0 psi < Fbx' = 1091.6 psi  (CSI = 0.34)   ➜  OK
fv* = = 16.71 psi
 fv* = 16.71 psi < Fvx' = 180.00 psi  (CSI = 0.09)   ➜  OK
fv = = 18.56 psi
 fv = 18.56 psi < Fvx' = 180.00 psi  (CSI = 0.10)   ➜  OK
6/17/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 225.50 / 0.13 = 1719
 ΔLL = 0.13 in = L/1719 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 225.50 / 0.21 = 1094
 ΔTL = 0.21 in = L/1094 < L/240   ➜  OK
Ab = b x lb = 3.5 x 2.5 = 8.75 in2
fc⊥ = = 56.3 psi
 fc⊥ = 56.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
6/17/2022 6
