Grade: SPF No.2
Size: 4 x 8
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Live Load: lbs
Dead Load: 30 lbs
Selfweight: 108.2 lbs
Dist. Selfweight: 5.35 plf
Total Weight: 109.6 lbs
CL Beam Stability Factor 0.965 - - - - -
Beam Design 2022A390
6/14/2022 1
6/14/2022 2
= 30.34 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (243.00 + 3)] x (12 in./ft.)3 = 3.61 ft3
Volumespan = N[A x L] = 1 x [25.38 x 243.00] x (12 in./ft.)3 = 3.57 ft3
Total Weight (WT) = ρw x Volumetotal = 30.34 x 3.61 = 109.6 lbs
Self Weight (WS) = ρw x Volumespan = 30.34 x 3.57 = 108.2 lbs
Distributed Self Weight (ws) = = 5.35 plf
lbs
30 lbs
ws = 5.35 plf
20.25 ft.
20.50 ft.
69.79 lbs
69.79 lbs
6/14/2022 3
lu = Unbraced Length = 20.250 ft.
lu/d = = 33.52
le = 1.37lu + 3d = 1.37(243.0) + 3(7.25) = 354.66 in. = 29.56 ft.  (NDS Table 3.3.3)
Rb = = 14.49
 Rb = 14.49 < 50   ➜  OK
6/14/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(1) = 459000 psi
FbE = = 2624.10 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.00)(1)(1)(1.3)(1)(1) = 1137.50 psi
CL =   = 0.965
Fbx' = (875)(1.00)(1)(1)(0.965)(1.3)(1)(1) = 1098.0 psi
fb = = 166.7 psi
 fb = 166.7 psi < Fbx' = 1098.0 psi  (CSI = 0.15)   ➜  OK
Fvx' = (135)(1.00)(0.97)(1)(1) = 130.95 psi
fv* = = 3.90 psi
 fv* = 3.90 psi < Fvx' = 130.95 psi  (CSI = 0.03)   ➜  OK
fv = = 4.09 psi
 fv = 4.09 psi < Fvx' = 130.95 psi  (CSI = 0.03)   ➜  OK
6/14/2022 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 243.00 / 0.00 = ∞
ΔTL =   =   = 0.21 in.
(L/d)TL = 243.00 / 0.21 = 1166
 ΔTL = 0.21 in = L/1166 < L/120   ➜  OK
fc⊥ = = 6.6 psi
 fc⊥ = 6.6 psi < Fc⊥x' = 284.75 psi  (CSI = 0.02)   ➜  OK
6/14/2022 6
