Design Span (L): 14.00 ft.
Clear Span: 13.75 ft.
Total Span: 14.25 ft.
Live Load: 82 plf
Dead Load: 0 plf
Selfweight: 61.2 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 62.3 lbs
Beam Design 2022A389
6/13/2022 1
6/13/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (168.00 + 3)] x (12 in./ft.)3 = 1.67 ft3
Volumespan = N[A x L] = 1 x [16.88 x 168.00] x (12 in./ft.)3 = 1.64 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.67 = 62.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.64 = 61.2 lbs
82 plf
0 plf
ws = 4.37 plf
13.75 ft.
14.25 ft.
615.42 lbs
615.42 lbs
6/13/2022 3
fb = = 802.6 psi
 fb = 802.6 psi < Fbx' = 862.5 psi  (CSI = 0.93)   ➜  OK
6/13/2022 4
fv* = = 46.55 psi
 fv* = 46.55 psi < Fvx' = 201.25 psi  (CSI = 0.23)   ➜  OK
fv = = 53.74 psi
 fv = 53.74 psi < Fvx' = 201.25 psi  (CSI = 0.27)   ➜  OK
6/13/2022 5
ΔLL = = 0.28 in.
(L/d)LL = 168.00 / 0.28 = 591
 ΔLL = 0.28 in = L/591 < L/360   ➜  OK
ΔTL = = 0.30 in.
(L/d)TL = 168.00 / 0.30 = 561
 ΔTL = 0.30 in = L/561 < L/240   ➜  OK
fc⊥ = = 136.8 psi
 fc⊥ = 136.8 psi < Fc⊥x' = 565.00 psi  (CSI = 0.24)   ➜  OK
6/13/2022 6
