Beam Design - Maryland
Live Load: 300 plf
Dead Load: 10 plf
Selfweight: 116.2 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 118.6 lbs
Beam Design Oscar Marryberg 215
6/13/2022 1
6/13/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 141.00] x (12 in./ft.)3 = 3.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.47 = 118.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.40 = 116.2 lbs
300 plf
10 plf
ws = 9.89 plf
1919.32 lbs
1919.32 lbs
6/13/2022 3
fb = = 1032.3 psi
 fb = 1032.3 psi < Fbx' = 1138.5 psi  (CSI = 0.91)   ➜  OK
6/13/2022 4
fv* = = 58.84 psi
 fv* = 58.84 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
fv = = 67.72 psi
 fv = 67.72 psi < Fvx' = 207.00 psi  (CSI = 0.33)   ➜  OK
6/13/2022 5
ΔLL = = 0.27 in.
(L/d)LL = 141.00 / 0.27 = 520
ΔTL = = 0.29 in.
(L/d)TL = 141.00 / 0.29 = 488
 ΔTL = 0.29 in = L/488 < L/240   ➜  OK
fc⊥ = = 142.2 psi
 fc⊥ = 142.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.23)   ➜  OK
6/13/2022 6
