Grade: 24F-V3 1.8E SP/SP
Size: 3.125 x 13.75
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 200 plf
Dead Load: 150 plf
Selfweight: 217.4 lbs
Dist. Selfweight: 11.01 plf
Total Weight: 220.2 lbs
Beam Design 2022A382
6/8/2022 1
b = 3.125 in.
d = 13.750 in.
A = 3.125 x 13.750 = 42.97 in.2
Sx = (3.125)(13.750)2/6 = 98.47 in.3
Sy = (3.125)2(13.750)/6 = 22.38 in.3
Ix = (3.125)(13.750)3/12 = 676.98 in.4
Iy = (3.125)3(13.750)/12 = 34.97 in.4
6/8/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [42.97 x (237.00 + 3)] x (12 in./ft.)3 = 5.97 ft3
Volumespan = N[A x L] = 1 x [42.97 x 237.00] x (12 in./ft.)3 = 5.89 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 5.97 = 220.2 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 5.89 = 217.4 lbs
Distributed Self Weight (ws) = = 11.01 plf
200 plf
150 plf
  ws = 11.01 plf
19.75 ft.
19.50 ft.
3610.08 lbs
3610.08 lbs
6/8/2022 3
fb = = 2145.1 psi
 fb = 2145.1 psi < Fbx' = 2760.0 psi  (CSI = 0.78)   ➜  OK
6/8/2022 4
fv* = = 110.01 psi
 fv* = 110.01 psi < Fvx' = 345.00 psi  (CSI = 0.32)   ➜  OK
fv = = 124.45 psi
 fv = 124.45 psi < Fvx' = 345.00 psi  (CSI = 0.36)   ➜  OK
6/8/2022 5
ΔLL = = 0.56 in.
(L/d)LL = 237.00 / 0.56 = 422
 ΔLL = 0.56 in = L/422 < L/180   ➜  OK
ΔTL = = 1.01 in.
(L/d)TL = 237.00 / 1.01 = 234
 ΔTL = 1.01 in = L/234 < L/120   ➜  OK
fc⊥ = = 385.1 psi
 fc⊥ = 385.1 psi < Fc⊥x' = 740.00 psi  (CSI = 0.52)   ➜  OK
6/8/2022 6
