Grade: DF SS
Design Span (L): 19.00 ft.
Clear Span: 18.75 ft.
Total Span: 19.25 ft.
Live Load: 10 plf
Dead Load: 7.5 plf
Selfweight: 49.1 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 49.7 lbs
Load Duration: 1.33
Beam Design 2022A380
6/8/2022 1
6/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (228.00 + 3)] x (12 in./ft.)3 = 1.45 ft3
Volumespan = N[A x L] = 1 x [10.88 x 228.00] x (12 in./ft.)3 = 1.43 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.45 = 49.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.43 = 49.1 lbs
10 plf
7.5 plf
ws = 2.58 plf
19.00 ft.
18.75 ft.
19.25 ft.
193.30 lbs
193.30 lbs
6/8/2022 3
Fbx' = (1500)(1.33)(1)(1)(1)(1.2)(1)(1) = 2394.0 psi
fb = = 827.6 psi
 fb = 827.6 psi < Fbx' = 2394.0 psi  (CSI = 0.35)   ➜  OK
6/8/2022 4
Fvx' = (180)(1.33)(1)(1)(1) = 239.40 psi
fv* = = 24.64 psi
 fv* = 24.64 psi < Fvx' = 239.40 psi  (CSI = 0.10)   ➜  OK
fv = = 26.32 psi
 fv = 26.32 psi < Fvx' = 239.40 psi  (CSI = 0.11)   ➜  OK
6/8/2022 5
ΔLL = = 0.32 in.
(L/d)LL = 228.00 / 0.32 = 704
 ΔLL = 0.32 in = L/704 < L/180   ➜  OK
ΔTL = = 0.65 in.
(L/d)TL = 228.00 / 0.65 = 350
 ΔTL = 0.65 in = L/350 < L/120   ➜  OK
fc⊥ = = 43.0 psi
 fc⊥ = 43.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
6/8/2022 6
