Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 500 plf
Dead Load: 195 plf
Selfweight: 111.2 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 114.2 lbs
Beam Design 853 Harbor Ct 2022A379
6/7/2022 1
6/7/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (111.00 + 3)] x (12 in./ft.)3 = 3.34 ft3
Volumespan = N[A x L] = 3 x [16.88 x 111.00] x (12 in./ft.)3 = 3.25 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.34 = 114.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.25 = 111.2 lbs
500 plf
195 plf
ws = 12.02 plf
9.25 ft.
9.00 ft.
9.50 ft.
3358.37 lbs
3358.37 lbs
6/7/2022 3
fb = = 956.0 psi
 fb = 956.0 psi < Fbx' = 1035.0 psi  (CSI = 0.92)   ➜  OK
6/7/2022 4
fv* = = 77.25 psi
 fv* = 77.25 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
fv = = 96.89 psi
 fv = 96.89 psi < Fvx' = 207.00 psi  (CSI = 0.47)   ➜  OK
6/7/2022 5
ΔLL = = 0.10 in.
(L/d)LL = 111.00 / 0.10 = 1151
 ΔLL = 0.10 in = L/1151 < L/180   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 111.00 / 0.14 = 814
 ΔTL = 0.14 in = L/814 < L/120   ➜  OK
fc⊥ = = 248.8 psi
 fc⊥ = 248.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.40)   ➜  OK
6/7/2022 6
