Grade: SP DSS
Design Span (L): 7.33 ft.
Clear Span: 7.08 ft.
Total Span: 7.58 ft.
Live Load: 38.5 plf
Dead Load: 15 plf
Selfweight: 64.1 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 66.3 lbs
Notes: Carport eave side beams.
Beam Design 1316 Leeward Lane 2022A374
6/6/2022 1
6/6/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (87.96 + 3)] x (12 in./ft.)3 = 1.78 ft3
Volumespan = N[A x L] = 2 x [16.88 x 87.96] x (12 in./ft.)3 = 1.72 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.78 = 66.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.72 = 64.1 lbs
38.5 plf
15 plf
ws = 8.75 plf
7.33 ft.
7.08 ft.
7.58 ft.
235.92 lbs
235.92 lbs
6/6/2022 3
fb = = 79.3 psi
 fb = 79.3 psi < Fbx' = 2070.0 psi  (CSI = 0.04)   ➜  OK
6/6/2022 4
fv* = = 7.55 psi
 fv* = 7.55 psi < Fvx' = 201.25 psi  (CSI = 0.04)   ➜  OK
fv = = 10.14 psi
 fv = 10.14 psi < Fvx' = 201.25 psi  (CSI = 0.05)   ➜  OK
6/6/2022 5
ΔLL = = 0.00 in.
(L/d)LL = 87.96 / 0.00 = 23789
 ΔLL = 0.00 in = L/23789 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 87.96 / 0.01 = 14713
 ΔTL = 0.01 in = L/14713 < L/240   ➜  OK
fc⊥ = = 26.2 psi
 fc⊥ = 26.2 psi < Fc⊥x' = 660.00 psi  (CSI = 0.04)   ➜  OK
6/6/2022 6
